Hi Rob,
Regarding Direction Setup Time: It shouldn't really make a difference if the system moves fast or slow. The problem occurs when the system reverses and where the speed would be very slow regardless. Closed loop could potentially correct the problem. If a micro step is lost or made in the wrong direction more will be generated until the encoder eventually reads the correct position. One problem with this is that the missed steps could accumulate over time to be a
very big value. So even though the axis would always be in the right place, the commanded position may be far off. This will prevent you from relying on following error to detect a stall, crash, or fault.
If you have the correct setting in the Config/Flash Screen and push "Move" on the Step Response Screen then the Parameters should be downloaded and set properly in KFLOP. So I can't see why it isn't working. We don't recommend Flashing parameters and Programs into KFLOP as it becomes confusing what has been changed. It is better to just start with a clean slate and set everything as
required. There is not usually any benefit to Flashing KFLOP when a PC will always be available to set things automatically. Try Flashing "New Version" to revert everything in KFLOP to default.
You might also test our hardware by just toggling the step signal using the Digital I/O Screen. You must cycle power on KFLOP for that to work. If the pins have been configured to a Step/Dir Generator they will not toggle as GPIO. Of course you must toggle many time before you will see much movement.
Message: 9438 |
Date: 5/1/2014 |
Subject: Re: Move and step on step response screen |
Hi Rob, Looks like that drive doesn't like negative going pulses. Strange most drives prefer that. Thanks for letting us know. Regards TK
